2022 New and Upcoming Releases!
Re: 2022 New and Upcoming Releases!
Isotope and Scottish Watches team up to create the Hydrium Alba.
The Isotope X Scottish Watches Hydrium 'Alba' is limited to only 100 pieces.
Now available to pre-order. Shipping Jan/Feb 2023
https://isotopewatches.com/products/hydrium-alba
Preorder price is £700 (roughly $847)
Isotope joined forces with Scottish Watches to create a limited version of the Hydrium divers' watch. Named 'Alba,' it pays tribute to the national colours of Scotland, featuring an enamelled dial and flame-blued hands.
- Micro-blasted case, 316L stainless steel
- Case diameter 40mm X 48mm (with lugs)
- Height 12.9mm (14.9mm with double domed Sapphire Crystal)
- Hydrium™ screw-down exhibition case back
- Uni-directional bezel with 120 clicks
- Anti-reflective crystal sapphire
- Screw-down crown at 3 o’clock
- Pure White enamelled dial, Railroad Track in Blue
- Isotope "i" hands Flame Blue Heated and filled with Super-LumiNova®
- Water-resistance 300m / 30 atm / 1000 ft
- 22mm Quick-release Blue FKM strap with signed micro-blasted Steel Buckle
- Swiss Landeron Mechanical Movement
New 100 piece limited release from Peren, the Nera Rogue BW.
Aka the @denormalize variant.
Available for immediate delivery.
https://perenwatches.com/watches-1/neraroguebw
CHF 595 on NATO, vegan silicone, or water resistant strap (roughly $634)
CHF 665 on bracelet (roughly $709)
- Movement: Swiss Automatic Sellita SW200-1, in-house regulated
- Diameter: 39mm
- Height: 12.80mm
- Lug to Lug: 48.80mm
- Case: Marine Grade Stainless Steel
- Finishing: Bead blasted / circular brushed / hand polished
- Bezel: Steel, Black PVD plated with straight knurling
- Bezel Insert: Stainless Steel with one layer of titanium nitride
- Functions: Rotating unidirectional 120 clicks
- Crown: Screw-down, embossed logo
- Crystal: Scratchproof Flat Sapphire with 3 anti-reflective layers
- Caseback: Bead blasted Stainless Steel, individual serial number
- Dial: Metal, embossed indexes, Date window, Black
- Hands: Steel, white, diamond cut
- Lume: BGW9 Swiss Super-LumiNova® on indexes
- Water resistance: 200m/660ft
Another Isotope limited edition, the Old Radium Bronze Tobacco, a limited edition of 100 numbered watches, ready to ship.
Changes the regular version include a no-date dial, and the inclusion of an additional Marine National style strap, handmade in Barcelona by Didymostraps exclusively for this Old Radium version. It comes with a buckle engraved with the Isotope name made out of CuSn8 bronze alloy.
https://isotopewatches.com/products/old ... ze-tobacco
Price is £900 (roughly $1,107)
You can read my review of a similar Old Radium here - viewtopic.php?f=38&t=4114
Kuoe have launched a new addition to their premium line, the Royal Smith 90-008
Royal Smith 90-008 is released as our flagship model from KUOE's premium line <Royal Smith>. Designed from the scratch with thoroughly selected parts. Inspired by antique watches from the 1940's, this model uses a cushion case that was common in those days. The classic Breguet numerals on the dial are individually hand-applied, and we give textures to the surface of the dial.The watch glass and caseback are equipped with domed sapphire crystals with AR coating.
Each watch is individually assembled by KUOE's own watchmakers in our workshop in KUOE KYOTO and delivered to you with great care.
https://www.kuoe-en.com/royal-smith-90-008
Price is $658
Available in either a stainless or gold tone case.
- Movement: Miyota - Cal.9039
- Case: Stainless Steel 316L
- Diameter: 34mm
- Lug to lug: 41mm
- Thickness: 11mm
- Lug width: 18mm
- Crystal: Domed Sapphire Glass with AR coating
- Water Resistant : 5ATM
Klaatu3
Post by Klaatu3 »
A repeat of Sept release..."back in limited stock" at the same $429 price, but
discount code SHOP15 brings it down to $364.65 + tax & shipping (tested).
https://countycomm.com/products/dual-cr ... %3D.TN7xPM
[No affiliation with CC, other than being a happy customer]
CC DC-50.JPG (71.62 KiB) Viewed 954 times
Klaatu3 wrote: Sat Sep 24, 2022 9:31 am County Comm out of Southern California has launched a new Maratac DC-50 compressor-type diver that is very well-spec'ed. Introductory price of $429. Get 10% off your cart with code CC4LIFE (tested) = $386.10 plus tax and shipping. Rated to 50 ATM/500M depth. Limit 1 per.
https://countycomm.com/products/dual-cr ... by-maratac?
Highights from the CC webpage:
1. BIDIRECTIONAL INTERNAL LOCKING BEZEL
2. AUTOMATIC HELIUM ESCAPE VALVE!
3. INCLUDES CUSTOM STAINLESS STEEL DOUBLE LOCK BRACELET WITH SCREW LINKS INSTALLED!
4. HIGH VISIBILITY DAY GLOW HANDS & TIMING CHAPTER!
5. 22MM STRAP SIZE WITH DRILLED LUG HOLES
6. SOLID MILLED END LINKS
7. 9015L MIYOTA 24 JEWEL HACKING MOVEMENT
8. SUPER-LUMINOVA® SWISS GRADE X1 ( TRIPLE APPLIED C3 )
9. 42MM CASE SIZE ( CROWN SIZE 6.5MM ) ( LUG TO LUG 50MM )
10. ROBUST SUPER THICK 3.5MM SAPPHIRE
- Klaatu3
