First Stage is a collaboration brand, bringing together Peter of Second Hour and Jack Hypoxia - a watch modder known around the world for his outstanding builds. They will be launching their first model, Shoal Deep, on Kickstarter starting Friday, April 21 @ 1AM AEST or Thursday, April 22 @ 11AM EST.
Super Early Bird pricing for stainless steel version is around $428
Early Bird is around $442
Standard pricing is around $457
Super Early Bird pricing for black DLC version is around $439
Early Bird pricing is around $457
Standard pricing is around $465
Estimated delivery is November 2022
Our first release, the Shoal Deep is a 300 metre diver built around the mid case design of the Seiko SKX - the OG modders case of choice. And we have modified everything - from the incredible dial, hands, unique bezel grip with ceramic insert, and case back, right through to the high beat Miyota 9039 automatic and the top grade beads of rice bracelet and fully milled, six micro-adjustment deployant clasp.
The Shoal Deep is available in three colorways - Shallows Blue, Kelp Green, or Blackout. Choice of a Stainless or black DLC case. And option of a Dive or 12 hour bezel.
- Automatic Movement: Miyota 9039 (no date)
- Case Diameter: 42.5mm (crown at 4)
- Case thickness: 13.76mm including double domed sapphire crystal
- Lug to Lug: 46mm
- Full 316L Stainless Steel Construction: case, crown, case back, bracelet and clasp
- Genuine Grade A Swiss BGW9 SuperLuminova on all elements
- Custom Bezel: Broad coin edge
- Custom Crown: Broad toothed matching the bezel
- Hands: Custom made, diamond cut, lume treated
- Applied Markers, lume filled
- Dial: Detailed oil pressed dials with our unique shoal design
- Ceramic Bezel Insert: 12 hour and dive time – deeply etched and fully lumed
- Crystal: Double Domed Sapphire Crystal with 6 layers of internal AR Coating
- Embossed Case Back: detailed fish shoal design
- Bracelet: Solid, screw link bracelet – solid end links, female head link
- Clasp: Milled Steel Clasp – 6 micro-adjustments
- Water Resistance: 300 Metres (30ATM)
SUCCESSFUL : Kickstarter: First Stage Watches - Shoal Deep 300m Dive Watch
Re: PREORDER: Kickstarter: First Stage Watches - Shoal Deep 300m Dive Watch
The Shoal Deep is now live
Re: SUCCESSFUL : Kickstarter: First Stage Watches - Shoal Deep 300m Dive Watch
122 backers pledged AU$ 76,955 to help bring this project to life.
You can still preorder directly from First Stage.
https://www.firststagewatches.com/shop
Preorder for stainless steel version is around $472
Preorder for DLC version is around $489
