Peren Watches, out of Transylvania, have opened preorders for their latest collection, the Regia and Regia X.
https://perenwatches.com/regia
Preorder price with a FKM or Fabric strap is CHF 693 (roughly $771)
Regular price will be CHF 963 (roughly $1,072)
Preorder price with a Bracelet is CHF 780 (roughly $868)
Regular price will be CHF 999 (roughly $1,111)
Estimated delivery is Q4 2023
The Regia watch is inspired by the Sarmizegetusa Regia Calendar, one of the most precise ancient calendar used by the Dacians in Transylvania. The calendar was based on a lunar-solar cycle, combining the phases of the moon with the movement of the sun.
The Sarmizegetusa Regia Calendar is subtly represented in the dial design as well as on the caseback.
The difference between the Regia and Regia X is the bezel design.
Regia:
Regia X:
- Movement: Swiss Automatic Sellita SW200-1, in-house regulated
- Diameter: 39mm
- Height: 12.80mm
- Lug to Lug: 45.30mm
- Case: Marine Grade Stainless Steel
- Finishing: Bead blasted / hand polished
- Bezel: Stainless Steel, straight knurling, circular serration
- Bezel Insert: Sapphire / Aluminum, unidirectional 120 clicks, Diver / 12H GMT
- Crown: Screw-down, concentrical serration
- Crystal: Scratchproof Flat Sapphire with 3 anti-reflective layers
- Caseback: Bead blasted Stainless Steel, individual serial number
- Dial: Metal, embossed indexes, Date at 12H, Black
- Hour Indexes: 3D SLN BlocksLume: BGW9 Swiss Super-LumiNova
- Hands: Steel, white, diamond cut
- Lume: BGW9 Swiss Super-LumiNova
- Strap: Fabric, FKM vulcanized synthetic high performance rubber, Steel bracelet
- Water resistance: 200m/660ft
PREORDER: Brand Direct: Peren Watches - Regia and Regia X
Re: PREORDER: Brand Direct: Peren Watches - Regia and Regia X
I like this one quite a bit.
Absolutely gorgeous, but that price tag isn't really justified by the specs.
I'm with you @Mot. The case seems familiar but I'm having a hard time remembering the minimalistic German brand that uses something similar
