2024 New and Upcoming Releases!
Re: 2024 New and Upcoming Releases!
Our very own @jts was "instrumental" (see what I did there?) in helping to design this Nodus x Pen Addict Edition Sector Dive GMT.
https://www.noduswatches.com/design-lab ... ct-edition
Price is $475
Preorder is a 50% deposit of $237.50
The preorder window to secure a watch will close at the end of March 27th.
Estimated shipping is for July 2024.
The Pen Addict is a weekly fix for all things stationery. Pens, pencils, paper, ink – you name it, and Brad Dowdy and Myke Hurley are into it.
Designed in collaboration with The Pen Addict podcast, the Sector Dive GMT TPA Edition benefits St. Jude’s – long time partner of The Pen Addict and Relay.FM. Crafted with the needs and desires of the Pen Addict community in mind, the TPA edition boasts a "Poker Chip" countdown bezel alongside a GMT complication.
The Pen Addict Edition ships with a Flat-Link Bracelet and Pecan Brown Horween Leather Strap.
MOVEMENT
- Seiko TMI NH34
CASE
- 316L surgical-grade stainless steel
- 39mm bezel width x 38mm case width x 12.75mm thickness x 47mm lug-to-lug x 20mm lug width
CROWN
- Screw-down crown
GLASS
- Flat sapphire crystal
- Blue anti-reflective coating on underside
BEZEL
- 60-click bi-directional bezel
- Anodized aluminum insert
LUME
- Swiss Super-LumiNova® BGW9 Grade A
WATER RESISTANCE
- 100 meters
BRACELET
- 20mm-16mm taper
- Proprietary NodeX Clasp
- Quick-release springbars
Didn’t know anything about this one……do not adjust your screen.
$205 - release in 22 hours.
https://launches.endclothing.com/produc ... w2w569007u
Probably not new, just me catching up to it.
CVP33 wrote: Sun Apr 21, 2024 6:43 am
That looks pretty good.
Case - Rolex Air King
Indices (if they were applied) - IWC spitfire
Dial - Zelos SkyRaider
And it works!
Only 20 numbered pieces…..$3,900 dollars?
https://depancel.com/en-us/products/htt ... Urg.VP6SG4
OOO distressed or ‘normal’ GMT’s. Some interesting colorways………
https://outoforderwatches.com/collectio ... sMY.QPEvZy
Nothing to see here.
CVP33 wrote: Fri Apr 26, 2024 3:05 pm Cestrian Watches up to 35% OFF - code PAYDAY15
https://cestrianwatches.com/pages/payda ... _98.Vggpq6
Should this be in the Heads Up thread?
TheJohnP wrote: Fri Apr 26, 2024 6:30 pm
Yup….should've been. Over-served…..
