PREORDER: Kickstarter: Kronozuri - Jump Hour Automatic Collection
Kronozuri, out of Hong Kong, have returned to Kickstarter for their second collection, the Jump Hour automatic.
This campaign is fully funded, as was their prior one.
And I am seriously considering backing this one myself.
48 Hour Special pricing is around $486
Regular pricing will be about $980
Estimated delivery is September 2024
The Kronozuri Jump Hour Automatic: An exclusive Swiss movement watch constructed with the highest quality materials and craftsmanship and made more affordable than any comparable competitor. The large jump hour window always displays the current hour while you can quickly discern the minutes from the large minute dish that spins around the dial. The circular jump hour is just above 12 o’clock and it’s constructed with a disk that rotates beneath its window such that each time the minute hand passes 12, the disk will “jump“ forward to the next hour.
The Jump Hour collection comes in four colorways - Blue, Black, Brown, and Grey
Case
· 316L Stainless Steel
· 39mm Width, 13mm Height
· Top double-dome sapphire crystal with antireflective coating
· Exhibition sapphire crystal caseback
· Push-pull crown
· Water Resistance: 5 ATM (50m)
Movement
· Sellita SW200-1 with Jump Hour module
Dial
· Double layer dial with Grade A Swiss Super-LumiNova® BGW9 pigment that is white in daylight and, when properly charged, glows blue-green in the dark.
Strap
· 20-18mm Italian leather with solid stainless-steel buckle.
Re: PREORDER: Kickstarter: Kronozuri - Jump Hour Automatic Collection
These are quite attractive. The blue or black would be my pick.
