Special pre-order price is $675.75
Coming December 2019
https://lum-tec.com/collections/350m-series
All new Anti-Magnetic 350 meter diver series for LUM-TEC.
Assembled by hand in Ohio
Width: 43mm excluding crown
Thickness (with glass) 12.0mm
Lug to lug length: 49.7mm
Lug width: 22mm
Water resistance: 350 meters
Swiss made Selita SW200-1 automatic movement
Precision tuned to +/- 0-3 seconds/day tolerance in six positions
Self-winding mechanism with ball bearing
28,800 vibrations per hour, 4 Hz. 26 jewels
Power reserve 38 hours
Anti-shock movement mounting system for increased durability
Movement fully encased in iron shielding for magnetic resistance up to 20,000A/m
Surgical grade 316L Stainless Steel forged and heat treated case
Alternating brushed and mirror polished with top level finishing
Ceramic bezel insert with MDV Technology illumination
120 Click Uni-directional bezel
Top grade genuine sapphire crystal
Military grade double anti-reflective coating
MDV Technology 30 layer raised luminous application
Mirror polished, diamond cut stainless steel hands
High tech Viton gaskets
Screw down crown with double diamond sealing system
Closed forged and CNC machined threaded caseback
Comfort engineered surgical grade forged 316L stainless steel bracelet
Button locking deploy clasp with ratcheting dive extension
Lifetime free timing adjustments, seal cleaning and pressure testing
2 year limited warranty
Pictures below look like renders to me
Preorder:LUM-TEC 350M Series
Re: Preorder:LUM-TEC 350M Series
Preorder is still live for anyone interested.
